SUPER Tool! But the new version has bugs and here some wishs
Discussions on XnView for PocketPC
luckyfreddy
Post by luckyfreddy »
Hi Community!
First, i want to send my biggest thank to the Author(s) of this great wonderful tool! On all my computers and those which i had installed for friends, i've installed this great tool and at my pocketpc has it been installed, too! GREAT!
The new version has some bugs - or functions which doesn't functionally well.
Some features or corrections are at my wishlist and i would pleased, if this list would be considered for the new version!
I would also be pleased about feedback!
The first point - Picture Quality:
The quality is perfectly and exact. But, if i see an image in the "screen-fixed" view, there are many stairway steps at the image.
The freewareviewer from PDAmill, (CHECK HERE), had got a very much sharper and more accurate picture in the "screenstretch-view". XnView is more powerful, so a such good picturequality in XnView were perfect and super!
Second point:
If i zoom in a picture in fullscreenmode used by tap and hold and close the program or change a picture and click at "fit to screen" and zoom later in, then the picture is very small and i must click and click to zoom the picture in.
Third point:
The zoomfunction with hardwarekeys is not the same wich "tap and hold" in fullscreenmode. Not useable :-(
Furth point:
If i tap in browser mode at an picture, it starts in fullscreenmode. In older versions it starts fitted in window with some icons down. This was better cause you could do more (light the picture up/down, etc.). Could you restore this?
I hope it is okay, that i post my wishes here and would be pleased about feedback.
And sorry for my worste english!
Greetings from Germany,
Christopher
Re: SUPER Tool! But the new version has bugs and here some w
luckyfreddy wrote:First, i want to send my biggest thank to the Author(s) of this great wonderful tool! On all my computers and those which i had installed for friends, i've installed this great tool and at my pocketpc has it been installed, too! GREAT!
Thanks ;-)
Ok, i'll check
luckyfreddy
Cool, thanks!
If there is an beta, i will be your tester ;)
luckyfreddy
Hi Pierre!
It's one of the best viewer, but the new version contains many from the old bugs... :(
@All:
Where could it get the old Versions from XnView, where i can zoom with the Stylus in Fullscreenmode - without "tap and hold"?
Christopher
luckyfreddy wrote: It's one of the best viewer, but the new version contains many from the old bugs... :(
Which bugs?
Design
Post by Guest »
Very funky i love it. ?
Madmax
thx and idea
Post by Madmax »
This viewer is the best i've test on my Axim X30. But i've a problem It's impossible to see photos from a network computer. I don't know if is a miss from me or Xnview ??
Can you help me please
May be it'a request for a futur version of xnview :)
Re: thx and idea
Madmax wrote:This viewer is the best i've test on my Axim X30. But i've a problem It's impossible to see photos from a network computer. I don't know if is a miss from me or Xnview ??
Yes, i don't support network with Pocket...
Zilexa2
Post by Zilexa2 »
dude, what bugs? you can zoom perfectly, you can set with what you want to zoom in the Settings. It is not a bug.. just change it in the Settings as you like.
