[OK]RC3: Deleted nameless folders remain in browser view
Locked
marsh
Post by marsh »
This problem occurs only when 'scan headers' is on:
In a directory containing multiple subdirectories, deleting one of them does not remove folder from view, a nameless, non-functional folder icon remains.
Re: RC3: Deleted nameless folders remain in browser view
marsh wrote:This problem occurs only when 'scan headers' is on:
I can't reproduce this bug. When i remove folder, thumbnail view or other is refreshed...
Dreamer
Post by Dreamer »
Works good here too, also with "Auto refresh" option disabled. What is your OS?
Dreamer
ckv
Post by ckv »
I got similiar bugs in 1.74, but I can't reproduce this bug in RC3. I look into it.
Edit: OK I got it already. I occurs only in thumbnails views.
I am using Windows 98 SE
Edit2: Occurs in all 'scan headers' modes with me. And I can't reproduce this in XP at all.
Edit3: Occurs also in XP, check below for mor info.
marsh
Post by marsh »
ckv wrote: I am using Windows 98 SE
I'm using Win2k (no new IE added), details view, auto-refresh on.
marsh
Post by marsh »
Happens in RC4 too.
ckv
Post by ckv »
I got breakthrough when debugging this bug.
OK heres how to reproduce.
- go to 'Options / Browser / File list'
- Check all checkboxes in both 'Items shown in...' groupboxes, except the 'All other files', uncheck them.
- Then go to Browser select thumbnails / (thumbnails & details) or details view.
- Browse to folder where are multiple sub directorys
- delete one of them (described bug should occur)
A nother way
- reproduce two first septs
- Then go to Browser select any other mode than last time.
- change view mode (described bug should occur)
and a nother
- reproduce two first septs except check also 'All other files'
- Then go to Browser select thumbnail or details view.
- Go to check 'All other files' checkbox (described bug should occur)
I got couple ways more to reproduce this, but this should be enough.
Note: You can use clean ini to test this, but it didn't make any difference for me.
ckit
Post by ckit »
Method 1 -> Confirmed in RC4
Method 2 -> Confirmed in RC4
Method 3 -> Confirmed in RC4
ckv
Post by ckv »
Occurs also in Windows XP
ckv wrote:Occurs also in Windows XP
Ok, very difficult to find ;-)
ckv
Post by ckv »
Fixed in RC5. :D Thanks Pierre
ckit, marsh. Could you confirm.
ckit
Post by ckit »
Method 1 -> Fixed in RC5
Method 2 -> Fixed in RC5
Method 3 -> Fixed in RC5
marsh
Post by marsh »
Fixed. No more problem with this for me.
Locked
