Missing folders refresh & disabled file functions
filo
Post by filo »
I have just installed XnView MP on Ubuntu desktop. I can't fix belows problems:
1) auto refreshing or manual refresh not working in Folder window. Only restart XnView working as folder refresh after changes of folder structure.
2) In Folder window after right click on folder showed list included disabled functions: Delete, Rename, Create New Folder.
Especially first problem makes working with that great application difficult.
Best, Filo.
JohnFredC
Re: Missing folders refresh & disabled file functions
Post by JohnFredC »
# 1 Confirmed.
However, MP does see the files in new folders when the user selects "Show all files (recursive)" from the tree context menu of the parent folder, even if the folder is not be visible in the tree.
The mini-toolbar needs the refresh button as in 1.9x, also, the refresh action should also refresh the folders list in the folder tree.
· Open browser
· Show folder tree
· Navigate to a folder with images
· Switch to another file tool (leave MP open)
· Make a new folder within the folder the MP browser points to
· Copy an image into the new folder
· Switch back to MP
· Observe that the new folder is not visible in the tree
· Perform View->Refresh
· Observe that the new folder is still not visible in the tree
· Right-click on current folder in folder tree
· Select "Show all files (recursive)"
· Observe newly copied file in file-list (or thumbs panel)
· Observe containing folder for that image still not visible in tree
John
filo wrote:1) auto refreshing or manual refresh not working in Folder window. Only restart XnView working as folder refresh after changes of folder structure.
I can't reproduce. The new folder is added in thumbnail view AND folder view
Please check XnViewMP 0.38
harkonen
Post by harkonen »
in .53, after adding new folder (in Windows 7) in sub folder of my documents, attempt refresh F5, folders in the do not appear after refresh. Only after exit xnview mp and restart xnview mp.
