[Fixed] RC3: opens off-screen?!
Locked
scratch
Post by scratch »
when using "fit image to desktop, large only", opening the main.bmp from any included skin occurs with the XnView window being off the left edge of the screen. i'm assuming this would happen with any image where the width is much larger than the height.
Re: RC3: opens off-screen?!
scratch wrote:when using "fit image to desktop, large only", opening the main.bmp from any included skin occurs with the XnView window being off the left edge of the screen. i'm assuming this would happen with any image where the width is much larger than the height.
Right, i'll fix it
Locked
