feedback on "Close other tabs"
budz45
Post by budz45 »
1. I think "Close other tabs" right-click feature should be greyed out if there is only one tab remaining on the tab bar. Currently if was to accidentally click on "close other tabs" on only one remaining tab then it would close the tab and go to Browser which is not necessary especially since "close other tabs" is multiple tabs opened.
So "close other tabs" needs to be greyed out if there is only one tab remaining.
I considered this more of a missing feature than a bug, hence why I posted this here
2. Similarly in another case the when there is only 1 browser tab and 1 viewer tab opened and I click "close other tabs" on the viewer tab then that needs to respond and close the browser tab same thing vice versa if I click "close other tabs" on the browser tab with 1 other viewer tab opened.
thanks for reading
budz45
Re: feedback on "Close other tabs"
Post by budz45 »
budz45 wrote: So "close other tabs" needs to be greyed out if there is only one tab remaining.
Or just not exist at all would be better.
budz45
Post by budz45 »
Fixed in XnViewMP 0.38 :P ('close other tabs' is now not present on single only tab)
