[Fixed]RC3: shift-delete = bypass recycle bin
scratch
Post by scratch »
could you make a hotkey of shift-delete, bypassing the recycle bin? this is a very handy shortcut used in windows explorer as well as many other file managers and image viewers. it's pretty standard on the windows platform.
ckit
Post by ckit »
It already exists!
Select a file and press Shift and DEL.
emaen
Post by emaen »
It already exists!
yes, but it does NOT bypass :wink: the recycle bin !
the delete file is send to the bin (just as pressing delete), but not directly delete from the hard disk.[/u]
ckit
Post by ckit »
Hmm, you're right.
I can't believe I didn't notice this before, I'm too used to it working perfectly in xplorer2 lite I guess.
Freeware-User
Post by Freeware-User »
You can in the Options > General , disable the option "Delete to recicle bin", and activate te option to "Confirm file delete".
:P
Free, even in software. # (Sorry for my english..) :( # PC Spec: P4, 512mb ram, Onboard VGA, WinXP Pro SP2 PTG
Danny
Post by Danny »
Freeware-User wrote:You can in the Options > General , disable the option "Delete to recicle bin", and activate te option to "Confirm file delete".
:P
Read again. That's not what he wants. Your suggestion would delete all files completely everytime. He wants to be able to choose for each file individually if it's going to be moved to the trashcan or deleted permanently.
Re: REQ: shift-delete = bypass recycle bin
scratch wrote:could you make a hotkey of shift-delete, bypassing the recycle bin? this is a very handy shortcut used in windows explorer as well as many other file managers and image viewers. it's pretty standard on the windows platform.
Yes currently SHIFT+delete don't ask you, but move the file in recycle bin.
Without recycle bin is really dangerous, but for power users....????
Definitely
:arrow: Pierre
:) Hi again!
- I use Shift+Del daily in Total Commander to delete files directly and definitely, and I couldn't notice a lot of disasters for years I work as is…
:mrgreen: KR
scratch
Post by scratch »
yes, for power users. shift-delete should ask you "do you want to delete the file permanently?" just like in explorer.
scratch wrote:yes, for power users. shift-delete should ask you "do you want to delete the file permanently?" just like in explorer.
Ok, i change it
ckit
Post by ckit »
This is fixed\added in RC4.
scratch
Post by scratch »
not for me. shift-delete still does nothing. could this be moved back to open bugs?
scratch wrote:not for me. shift-delete still does nothing. could this be moved back to open bugs?
Shift + del works for me. Where do you use it?
scratch
Post by scratch »
i use it in view/edit (the mode i spend probably 90% of my xnview time in). just tried in browse and it works there. delete works in view/edit though, so why not shift-delete?
Dreamer
Post by Dreamer »
(It works in the browser, therefore moved to "Solved" forum...)
Add it also to view/edit mode is a good idea, maybe even a minor bug...
Locked
