[Fixed]RC3: minimum window width
Locked
scratch
Post by scratch »
could you perhaps either implement a configurable setting for the minimum window width, or at least make it larger than its current setting? currently, with small images, the window gets so small that the menubar wraps to two lines, and this looks really bad in my opinion. acdsee, for example, sets a minimum window width big enough so this doesn't occur.
Re: REQ: minimum window width
scratch wrote:could you perhaps either implement a configurable setting for the minimum window width, or at least make it larger than its current setting? currently, with small images, the window gets so small that the menubar wraps to two lines, and this looks really bad in my opinion. acdsee, for example, sets a minimum window width big enough so this doesn't occur.
When you have in "Fit to image", right?
scratch
Post by scratch »
exactly, yes. either fit to image or fit to desktop, large only.
scratch
Post by scratch »
this is either unfixed (if you have hardcoded a new width) or i can't find the option (if you added an option).
scratch wrote:this is either unfixed (if you have hardcoded a new width) or i can't find the option (if you added an option).
Strange i have fixed it but seems to be not fixed :-((( I'll fix it
scratch
Post by scratch »
confirmed fixed. thanks so much, this one was really bugging me. :D
Locked
