General topic for help with translation
Translation of On-Screen texts of XnView MP and XnConvert
Skiff
Post by Skiff »
Most recent language files for XnView MP can be downloaded here: http://download.xnview.com/XnViewMP-translation.zip
___
Hello, I think we need general topic for help with translation of XnViewMP.
Now I have some problem with translating:
    <message>
        <location filename="DlgConvertProcess.h" line="2426"/>
        <source>Normalize Ex</source>
        <translation type="unfinished"></translation>
    </message>
What does 'Ex' mean? Exponential? or something else?
In regular XnView translation I had the same problem, and probably this isn't translated correctly... :(
Please help
Re: General topic for help with translation
Skiff wrote:Hello, I think we need general topic for help with translation of XnViewMP.
Yes, a good idea, Skiff. Please note that we have a general topic for Translation tricks and traps, already. But not a general topic for questions.
Skiff wrote:What does 'Ex' mean? Exponential? or something else?
Just guessing: Extended?
What does "Conbright" stand for? Contrast & Brightness? And the same with "Gammasat" (Gamma/Saturation). Translating and then combining the two words does not work very well. :-|
Moderator & Librarian
Ex¬posure?
KPAH ([url=http://newsgroup.xnview.com/viewtopic.php?p=84211#p84211]RAW processing, batch noise reduction and normilize[/url]) wrote:Image->Ajust->Normalize
Is that what is commonly called Exposure?
If not, how can I edit exposure?
Ex¬pansion?
  • Image » Adjust » Normalze... » Expansion limit %
Netpbm: Pnmnorm User Manual
Yes
It's the name from author of this method, so no need to translate...
Skiff
Post by Skiff »
Thanks, now I've done translation for 0.27. Attaching in appropriate topic.
@Helmut: I've seen 'Translation Tricks and Traps' topic but questions would be better separated
Skiff wrote:Thanks, now I've done translation for 0.27. Attaching in appropriate topic.
Could you send me it?
Skiff wrote:...but questions would be better separated
Yes, I agree(d). Just wanted to make sure that people are aware of the T³ topic (Translation Tricks and Traps). ;-)
Some English terms which don't mean much to me:
1 - QtCopyDialogPrivate > Force: Cannot remove destination file
2 - DlgExportClass > Up
3 - ItemModel > Line
Can someone please help and explain?
helmut wrote: 1 - QtCopyDialogPrivate > Force: Cannot remove destination file
When destination file can't be removed
Name of PNG filter, Up/Paeth/Avg can be kept in english
When you are in details, you can add Line number to the displayed column
Thank you for your replies, Pierre.
O.k.. And what does "Force" mean?
When you are in details, you can add Line number to the displayed column[/quote]
Hmm, can't find it. Where and how do I set the Line number?
helmut wrote:Thank you for your replies, Pierre.
Don't know ;-) QtCopyDialog is not from me
In details, right click to choose which column you would like
Skiff
Post by Skiff »
1. What does
<location filename="DlgSettingsInterface.ui" line="53"/>
<source>Synchronize browser when view is closed</source>
do?
Browser is synchronized with what?
2. Same with
<location filename="DlgSettingsView.ui" line="372"/>
<source>View all icons in the file as snapshot</source>
What icons, and what snapshot?
Serezha
Post by Serezha »
Hello! Everywhere it is mentioned "Camera RAW", it should be translated? In some places it seems to me it is necessary to leave simply "RAW"?
Serezha wrote:Hello! Everywhere it is mentioned "Camera RAW", it should be translated? In some places it seems to me it is necessary to leave simply "RAW"?
Camera Raw (please note the lowercase of "Raw") means the raw data format of the camera. In some languages (e.g. German) the term has found an appropriate translation, but in many languages (e.g. German ;-) ) the original term is also understandable or even clearer. Perhaps you search for websites in your language a bit to see whether translations are available. With leaving the term "Camera Raw" you should be pretty much on the safe side.
