Would like to use AppData files in program folder
budz45
Post by budz45 »
I would like to custom move and use such files as bookmarks.ini in the program's folder instead of the win AppData folder, but as my own choice. Current MP 0.31 doesn't support reading bookmarks.ini , style, database files etc from the program folder (portable use). I understand that especially, the database files can grow in great filesize but in my own portable use I don't care. Would be a nice background feature to add. Just my thought.
xnview.ini already works just fine in program folder, so custom ability for the rest would be good too.
JohnFredC
Re: Would like to use AppData files in program folder
Post by JohnFredC »
budz45 wrote:Current MP 0.31 doesn't support reading bookmarks.ini , style, database files etc from the program folder (portable use).
Hmmm. I checked the behavior just now and, (on my system) all 0.31 user files (ini, bookmarks, bars, etc) are currently being stored in the same folder as the executable. :?:
John
budz45
Post by budz45 »
Sorry for late reply.
I actually meant these files...
Would be good (esp. for Portable lovers) to be able to custom have everything in one folder
btw I just updated 0.33 to 0.35
Do you have changed integration>Other files?
budz45
Post by budz45 »
xnview wrote:Do you have changed integration>Other files?
Oh right, so you mean Settings>Integration>(folder used for other files) I have to change from "user" to "xnview"??
yes
