WebP support
MaxSt
WebP support
Post by MaxSt »
New image format from Google:
http://code.google.com/speed/webp/gallery.html
The format Is very young, so no image viewers support it, but... it's a good opportunity for XnView to be the first! Please, add WebP support!
Re: WebP support
Yes, i've seen it :-)
Drahken
Re: WebP support
Post by Drahken »
I think webp is a bad idea. There are already several JPG replacement formats floating around (jpeg 2000, hdphoto/jpeg-xr for example), and none are getting very widespread support yet (jp2k's the best supported, but it's been around for many years now & seems likely to die a quiet death). Adding yet another one at this point will only muddy the waters & make it so that none of them get widespread support. Additionally, the size improvements aren't very significant over JPEG, and webp is apparently limited to the lowest quality chroma subsampling (meaning all webp pics will look as bad as the worst jpeg pics). High quality subsampling (ie, no subsampling) has a massive effect on quality while only impacting filesize slightly, throwing that away in webp is indescribably stupid.
It would probably be best for xnview to support webp since ones of xnview's best features is the fact that it can read nearly any image format, but I hope the webp format itself dies off quickly.
MaxSt
Re: WebP support
Post by MaxSt »
Drahken wrote:Adding yet another one at this point will only muddy the waters & make it so that none of them get widespread support.
Trying new things is always good. Look at video codecs, how many new ones we saw since DivX 3 days? Probably hundreds. They compete, they learn from each other, some die, but top codecs right now are much much better than DivX 3.
Two jpeg alternatives in 20 years is not enough. Let google try. Let hipix try.
If they'll fail, others will learn from it.
Drahken wrote:webp is apparently limited to the lowest quality chroma subsampling
It's not just subsampling in encoder, but decoder have to upscale it correctly. Right now their decoder is absolute crap. Instead of interpolating chrome samples, it just doubles them. I send them some horribly pixelated examples, and they promised to fix it:
http://code.google.com/p/webp/issues/detail?id=14
Drahken wrote:I hope the webp format itself dies off quickly.
I hope WebP can and will be improved. They are not experts in image compression, but they could learn.
DOS386
Re: WebP support
Post by DOS386 »
JPEG-2000 is proprietary (RTFL) so it's useless. Similar applies to other competitors: proprietary or too slow, useless.
Good point.
MaxSt wrote:Trying new things is always good.
Not always. New things are only good if they are significantly superior to old stuff and don't have critical regressions (JPEG-2000 has a critical regression in license/legal area).
99.9% of them are useless ;-)
Just the competition is far away from fair :-(
BTW, there is a need for a JPEG replacement, for following reasons:
- Lossless JPEG "recompression" exists (JPEG must be bad if this really works ...)
- JPEG spec is bad (too complicated, only a subset is used)
http://code.google.com/speed/webp/faq.html
http://code.google.com/speed/webp/docs/ ... ainer.html
Also, this WebP is based on VP8 video codec (good) but the RIFF is a very bad idea. I haven't really evaluated the thing yet.
What I primarily want to see about WebP (or any other JPEG replacement or some other new thing) one day is a high quality specification.
MaxSt
Re: WebP support
Post by MaxSt »
DOS386 wrote:Not always. New things are only good if they are significantly superior to old stuff and don't have critical regressions
Always. Not-superior ones could serve as a learning experience for others. I consider it good too.
rabbat
Re: WebP support
Post by rabbat »
MaxST,
check out the nightly build of Chromium and the updated lib-webp-decode
has been addressed
budz45
Re: WebP support
Post by budz45 »
Another sample gallery;
http://code.google.com/speed/webp/gallery1.html
Right,
It would be good if WebP and WebM as now added to the XnView 'Formats' website page :)
http://xnview.com/en/formats.html
DOS386
Re: WebP support
Post by DOS386 »
budz45 wrote:would be good if WebP and WebM as now added to the XnView 'Formats' website page http://xnview.com/en/formats.html
WebP is already there (but fails to mention that only by plugin, and how far this includes the later lossless and transy flavor, or not).
WebM is a video format and NC/XN doesn't support it.
eL_PuSHeR
Re: WebP support
Post by eL_PuSHeR »
I downloaded a precompiled win32 version yesterday. It includes the lossless format to transform from and to PNG. The lossless format has a webpll extension and cannot be opened yet.
Lossy compression can be opened normally under XnView (using 1.98.6), but when invoking file properties it shows compression: none.
It should say compression: webp lossy.
png2webpll is also SLOW AS HELL (but Google already stated that at this moment).
It packs files tighter than PNG though. It would be real cool if XnView would support this lossless flavour although I find rather idiotic to use a separate file extension for it.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
Drahken
Re: WebP support
Post by Drahken »
Have you tried renaming the file to a webp extension & see if xnview can open it?
eL_PuSHeR
Re: WebP support
Post by eL_PuSHeR »
Yes I did.
Headers are completely different
Start of WEBP Lossy header:
RIFF:ø WEBPVP8
Start of WEBPLL Lossless header:
È8’Øæ
A(
They are completely different formats (Google already stated that too).
Intel i7 5960X
8 GB DDR4 (2100)
DOS386
Re: WebP support
Post by DOS386 »
I downloaded some binaries from "Nov 17" ... authors don't offer a single lossless file themselves!!! (there are a few lossy ones, finally). I started it ... no result ... either it hangs or it's too slow (PNGOUT was done after few s with same image). OK, got a result, only with -c 0 2x bigger then PNG ... and at least 10x slower than PNGOUT, messages are strange, what's the default value of "c" ??? Where is TFM ? Where is the spec ? File begins with $42 $15 $DC $A8 ... it's a completely different format. Why don't they put "WebP" in there (with some non-printable char's like PNG did) ? :-(
eL_PuSHeR
Re: WebP support
Post by eL_PuSHeR »
No. It's not hanging. It's just pretty slow. Try with a small PNG file first (maybe less than 50KB in size).
Intel i7 5960X
8 GB DDR4 (2100)
Froggy01
Re: WebP support
Post by Froggy01 »
I just want to make a small remark about WebP format support in XnView:
In the formats documentation page, it is not metionned that a plugin is required to read WebP images...
There should be a blue image like this Image
Not sure if this topic is appropriate, but I found no one more relevant...
