MP 0.26.1 WinXP: cannot zoom in to 100% on very large images
Zverik
Post by Zverik »
On just large pictures MP zooms in to 25%, than in a second zooms back to whole image, and then I can zoom all the way to 100%.
On very large ones, 10000x10000 and more, MP either zooms to like 20% and tells it's 100%, or zooms to 25% and refuses to zoom further.
By the way, thank you for the MP version: I'm turning to ubuntu soon :)
Re: MP 0.26.1 WinXP: cannot zoom in to 100% on very large im
You can't zoom to 100%??? when you press '*'?
JohnFredC
Post by JohnFredC »
I encounter no problems using MP to open that image. Zooming behaves correctly.
OTOH, 1.97.8 will open it in full screen and zoom properly, but will not open it in a tab, showing a "Warning: Not enough memory" message, instead.
WinXP, 2Gb.
John
Zverik
Post by Zverik »
Ok, here are steps to reproduce the bug on my system (XP SP2, 2GB RAM), I've just done the same to make screenshots:
1. Download http://download.xnview.com/XnViewMP-win.zip (MP 0.26.1 beta)
2. Unpack and run xnview.exe from that folder
3. Open ld_1947.jpg (or run "xnview.exe ld_1947.jpg" from command line, doesn't matter)
4. Press '*': http://not.textual.ru/zverik/2/3/xnmp-100percent.gif (note '100%' at the bottom)
5. Zoom in to 400%: http://not.textual.ru/zverik/2/3/xnmp-400percent.gif
5.1. (and scroll to the center, because xnviewmp zooms to the upper left corner: very uncomfortable)
6. Close XnViewMP and open XnView 1.97 (I use 1.97.2)
7. Open ld_1947.jpg and press '*': http://not.textual.ru/zverik/2/3/xn197-100percent.gif
Zverik
Post by Zverik »
The problem persists in MP 0.31w.
Also, I wasn't able to open images with double-click or Enter: they were being opened in default XnView instead. I had to manually choose 'Open' in pop-up menu.
