[Fixed] RC2 BUG: Batch Rename - First letters uppercase
Locked
Dreamer
Post by Dreamer »
Batch Rename > Case > First letters uppercase - first word is lowercase, others are OK - First letters uppercase.
E.g.: aaaa Bbbb Cccc Dddd 001.jpg
marsh
Post by marsh »
I see the problem too:
'First letters uppercase' displays backwards (lowercase).
New Problem:
It does not work. It will not rename files.
Dreamer
Post by Dreamer »
marsh wrote:New Problem:
Yes - if you want just change case, not rename files, case is not changed, bug #2.
Ok, i'll fix it
Dreamer
Post by Dreamer »
Fixed in RC3, thanks Pierre.
Locked
