[Fixed] RC2: Sorting by extension
Locked
Danny
Post by Danny »
Seems to have a bug. It will first list all files with their extension in CAPITAL LETTERS and then all the files with small letters. Like:
movie1.MPG
movie3.MPG
movie2.mpg
I don't think that's supposed to be, is it?
ckit
Post by ckit »
I do not have this problem.
BTW, please add "RC2:" to the beginning of the Subject line.
Re: Sorting by extension
Danny wrote:Seems to have a bug. It will first list all files with their extension in CAPITAL LETTERS and then all the files with small letters. Like:
movie1.MPG
movie3.MPG
movie2.mpg
No sorry i have not the problem. Which sort do you use?
Danny
Post by Danny »
xnview wrote:No sorry i have not the problem. Which sort do you use?
Which sort? Like the topic says - by extension. I did a clean install of RC2. That means no RC1 .ini is being used. Here's a picture:
I can try it over and over again. Same thing. First all file extensions with capital letters then those with small letters.
ckit
Post by ckit »
Can you go into DOS (command.com or cmd.exe) and type "dir h:\" and make a screenshot of it. Windows can play funny games when it comes to uppercase and lowercase filenames.
Ok, right, i fix it
Olive
Post by Olive »
Yup fixed for me (RC3)
Dreamer
Post by Dreamer »
Fixed in RC3, thanks Pierre.
Locked
