RC1: Thumbnails don't display correctly.
Locked
Nelson
Post by Nelson »
I have some digital photos.
Here's the problem:
1. The photo's height is bigger than it's width.
- So, it should "stands up".
2. The Preview panel shows correctly.
- That is, it stands up.
3. But the thumbnail doesn't.
- It lies down.
Can you fix it ?
Thanks a lot.
Hacker
Post by Hacker »
Cannot confirm. Works fine here.
Roman
Lesmo16
Post by Lesmo16 »
Nelson wrote:1. The photo's height is bigger than it's width.
- It lies down.
@nelson:
If I got you right ...
1. is a portrait
2. preview is fine
3. thumb isn't automatically rotated
You have to check:
Options -> Browser -> Thumbnail -> Use embedded thumbnail
Options -> Read -> Rotate images based on EXIF orientation
... should work! :wink:
Everyone who believes in telekinesis, raise my hand!
Post by Guest »
Lesmo16 wrote: If I got you right ...
1. is a portrait
2. preview is fine
You have to check:
Thank you for your reply. But it doesn't work.
Let me speak more detailly.
1. I have a portrait. Assume it is 800x600.
2. I use other image viewer's JPEG Lossless Transformation to rotate it.
3. Now, preview is fine, but thumb isn't.
4. Other image viewer, such as IrfanView or XnView 1.74, works fine.
So, I think this is a bug.
Nelson
Post by Nelson »
1. is a portrait
2. preview is fine
You have to check:
Forgot to say,
I had emptied cache, also I refreshed and restarted XnView.
But it can't work fine.
Anonymous wrote: Let me speak more detailly.
Do you have enabled the cache? Do you use embedded thumbnail?
Post by Guest »
Yes and Yes.
Yes and Yes.
Could you send me a sample, please?
Olive
Post by Olive »
This bug - Thumbnail not updated after JPEG lossless rotation - has been fixed.
This one has been open for a long time and never been reproduced properly. So I'm closing it now. Closed.
Locked
