RC1: RecentPaths combo truncated
Locked
JohnFredC
Post by JohnFredC »
If the thumbnail panel is too narrow, the dropdown for recent paths is also too narrow.
Image:
http://www.jfcinc.net/Interfaces/xnview180bug02.png
Even if there is not enough room to show the entire control in the toolbar, when "dropped down", the width of the list should be a usable size.
I know it is possible, programming-wise. The Favorites dropdown (the "star") shows correct behavior.
John
ckit
Post by ckit »
You need to delete your old "xnview.ini" to fix this.
JohnFredC
Post by JohnFredC »
Which xnview.ini did you mean? 1.8RC1 made its own ini in its own folder.
I won't be deleting the 1.74 ini until I switch to 1.8...
John
Dreamer
Post by Dreamer »
Try rename ini file only, in RC1 folder (to xnview.ini.bak) and let xnview to create new one, open xnview, close xnview and check if the problem is still there...
Dreamer wrote:Try rename ini file only, in RC1 folder (to xnview.ini.bak) and let xnview to create new one, open xnview, close xnview and check if the problem is still there...
I've fixed this problem.
In RC3, the problem still can be seen: When making the area of the file list small and then opening the dropdown list with most recent adresses, the list is as narrow as the dropdownlist itself.
I've just tried in another application, and there the same is happening. So I think this is standard behaviour of the dropdownlist control.
Note: The favourites menu is not a real dropdown list.
JohnFredC
Post by JohnFredC »
I use a combobox control in my MSAccess applications. It has a property called "listwidth" which sets the drop-down list's width independently of the control width...
So at least it's possible.
John
helmut wrote:In RC3, the problem still can be seen: When making the area of the file list small and then opening the dropdown list with most recent adresses, the list is as narrow as the dropdownlist itself.
Yes :-(
Minor issue. Closed.
Locked
