Are Categories Working Yet
RightPaddock
Post by RightPaddock »
Could someone confirm that the mechanisms to assign categories to images is yet to be implemented.
I can maintain the category tree but I can't find any means of assigning categories to images - there's no Set Categories item in the View menu as there is in the Windows version.
Right Paddock
Re: Are Categories Working Yet
RightPaddock wrote:Could someone confirm that the mechanisms to assign categories to images is yet to be implemented.
I have not yet added 'set categories' in view mode, but don't use it the DB can be changed
RightPaddock
xnview wrote:I have not yet added 'set categories' in view mode, but don't use it the DB can be changed
Thanks, I was concerned that I might be overlooking something obvious.
I won't be using XNView MP for anything meaningful prior to its release, so changes to the D/B schema during development will not be a problem.
:?: Will MP provide a facility to import XNView Categories from IPTC Supplemental Categories :?:
I appreciate that there are no "standards" for representing hierarchies, but there are a couple of conventions. Dotted as in "Sporting Venue.Race Track.Longchamps" and Braced as in {Sporting Venue,Race Track, Longchamps} are two I've come across. The dotted notation is used by IMatch, ACDSee Pro.and idImager (I think).
Hierarchies can be represented in XML, hence they can be represented in the XMP block, although it's much less readable for those of us who didn't learn XML on our mother's knee :wink:
Right Paddock
RightPaddock wrote:[
Yes, currently i think for categories<=>keywords. For you, supplemental categories should be used too?
I'll try to add a try in the next version...
RightPaddock wrote:The dotted notation is used by IMatch, ACDSee Pro.and idImager (I think).
Could you send me a sample?
ACDsee Pro can write categories in file and not only in DB??
