Scrolling thumbnail list to the end -> then it jumps back
wardenzanti
Post by wardenzanti »
I didn't find anything about this bug.
My problem is the following. When I open a folder and it creates the thumbnails. Now, If I scroll down to the end before the thumbnails were completley created it jumps back to the top at the time of the completion of the thumbnail list.
It annoys when the folder got more over 100 images in bigger size (thumb creation takes more time, scrolling down and then jumpback -_-)
Can this be fixed?
Thanks in advance!
Re: Scrolling thumbnail list to the end -> then it jumps
In Option/File list you have disabled 'all other files'??
wardenzanti
yes, same.
wardenzanti wrote:yes, same.
Which sorting do you use?
wardenzanti
nothing special, standard stettings.
Do you have the problem with clean .ini?
