SE RMB GPF OMG
Moderator & Librarian
SE RMB GPF OMG
Upon right-clicking an image file the new Shell Extension crashes my file managers.
This occurs with both Ontrack PowerDesk Pro v5.0 and Explorer under Windows 2000 SP4. :?
Aside ?
:arrow: XnTriq
:) Hello !
• Maybe is it a bit off topic, but here the ShellExt has gone from my local menu after I upgraded
to the last version coming with the 1.94 ß1 ! :(
• But still, it's stated as "Active" when checking with ShellExView, and worked alright in all previous versions…
- Attempting to force the loading with the <register.bat> is no-go :  I get a CMD error message telling that the file
is not executable (!) that indeed is wrong.
- I rummaged a bit in the registry, all keys are there, and seem correct :
• I translated roughly on that image, my ShellExView is (strangely :P) in French…
:mrgreen: KR
Re: SE RMB GPF WTF
XnTriq wrote:Upon right-clicking an image file the new Shell Extension crashes my file managers.
On windows explorer too?
No more XnViewSheelEx in your menu? For all images?
Vanished
:arrow: Pierre
:) Hello !
• Right, totally vanished, no matter which image file type I right-click on.
- It's missing from TC, Win Explorer and any other file manager…
• I've disabled >> Re_enabled it from “ShellExView”, unsuccessfully…
:?: Any clue ?
:mrgreen: KR
Re: Vanished
Clo wrote: • I've disabled >> Re_enabled it from “ShellExView”, unsuccessfully…
Do you have tried regsrv32?
Re: SE RMB GPF WTF
ShellExView v1.19:
Windows Explorer crashes when I try to go to the Options... sub-menu of the shell extension.
Read above---
:arrow: Pierre
:) Hello !
• Please, read above about the try with the register.bat file :|
:mrgreen: KR
Re: Read above---
Clo wrote: • Please, read above about the try with the register.bat file :|
Very strange, i've tried and no problem to register it
Solved !
:arrow: Pierre
:) Hello !
• Finally, the solution is on the screen shot above :  The file size is smaller by 1,096 bytes, comparing with the XnTriq's one !
- I downloaded the archive again an changed the DLL, it works now !
- It's odd, since I didn't get any error message for a “damaged¦invalid” file. :?
:mrgreen: KR
Re: Solved !
Good detective work, Clo!
  1. 5.909.066 bytes (18/Jun/2008 08:30)
  2. 5.877.917 bytes (19/Jun/2008 12:03)
XnView-beta1.zip #2 doesn't include AddOn\Pocket.xnp.
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=62928#62928]XnView 1.94 beta 1[/url]) wrote:
ckit wrote: Good work, Pierre!
How many times do I need to repeat myself before you destroy this DLL once and for all? Who cares about PDA's anyway?
Sorry, i forget always to remove it before packaging...
Re: SE RMB GPF WTF
I can't reproduce on 2K SP4. Could you try with clean settings?
Re: SE RMB GPF WTF
  • I removed xnview.ini.
  • I threw out all references to XnView in the registry (even those for XnViewQT).
  • I deleted all files in %AppData%\XnView\.
  • I rebooted my machine.
PowerDesk still crashes right away. Windows Explorer crashes as soon as I click on one of the items (Convert..., Copy to Clipboard, Options..., etc.).
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=47960#47960]XnView crashing after using shell context menu?[/url]) wrote:Besides the XnView shell extension I have a few others installed: 7-Zip, FmView, Ninotech Path Copy, Ontrack PowerDesk Pro, Properties Plus, WinRAR, WinZip.
Re: SE RMB GPF WTF
:-( I've installed PowerDesk, winrar, Zzip and no crash
PowerDesk crash when you right click?
Re: SE RMB GPF WTF
xnview wrote:PowerDesk crash when you right click?
Yes, I never get to see the context menu in PowerDesk.
xnview wrote::-( I've installed PowerDesk, winrar, Zzip and no crash
Thanks for your efforts, Pierre!
Don't waste your time on this one (as long as we don't get similar reports from other users). I'll try to remove all 3rd-party shell extensions one by one in the coming days, and once I've found out if the problem persists or not I'll get back to you.
Re: SE RMB GPF WTF
Do you have tried the beta 2?
