gflLoadBitmapFrom[Memory/Handle] with Plugins
pber
Post by pber »
Hello again,
I tryed to load pictures with the gflLoadBitmapFromMemory / gflLoadBitmapFromHandle functions.
I first tested .bmp files, and that was OK.
But when it came to .exr or .wlm files, the gflLoadBitmapFromMemory / gflLoadBitmapFromHandle returned GFL_ERROR_UNKOWN_FORMAT, as if they did not support the plugins.
Those files are compatible with the plugins, since I tryed to load them with gflLoadBitmap(...), and encountered no error in that process.
Are plugins loaded in the gflLoadBitmapFromMemory and gflLoadBitmapFromHandle ? (that would explain my difficulties to read those pictures :p)
Re: gflLoadBitmapFrom[Memory/Handle] with Plugins
pber wrote:Hello again,
Not all plugins are supported in GFL, such as WLM
To be able to load exr, you must have IlmImf.dll in Plugins folder
pber
Post by pber »
I have those, and the MSVCP71.DLL files.
That's maybe why I can load .exr files with the gflLoadBitmap function.
And I also have the Xwlm.dll file in the correct folder. Allowing me to load .wlm files with gflLoadBitmap function.
But I can find no reason for not being able of loading the files with the gflLoadBitmapFromHandle function.
pber wrote:I have those, and the MSVCP71.DLL files.
Ok, some format like EXR works on file and not handle, so *FromHandle is not possible
pber
Post by pber »
Is there a list of formats unavailable to gflLoadBitmapFromHandle / gflLoadBitmapFromMemory ?
As far as I have tried, exr and wml seem not compatible.
