XnViewShellExt V2.00 beta
* lng file for translation
* convert/resize + options
* edit iptc
If you have any bugs, please tell me before i release it...
http://www.xnview.com/beta/XnViewShellExt.zip
Re: XnViewSellExt V2.00 beta
No feedback?
ckit
Post by ckit »
I've had no problems so far but I'm not really using the new features yet :(
Post by Guest »
... I don't get how to edit IPTC or set the options for converting files - the context menue only shows the thumb, a "convert to"-dropdown menu, a "set as background image" option and an "options"-dropdown menu which offers the possibility to set the language and set the size, quality and orientation of the thumb :-( Do I miss something? (Sytem: Windows2000)
Thanks
Frank
Anonymous wrote:... I don't get how to edit IPTC or set the options for converting files - the context menue only shows the thumb, a "convert to"-dropdown menu, a "set as background image" option and an "options"-dropdown menu which offers the possibility to set the language and set the size, quality and orientation of the thumb :-( Do I miss something? (Sytem: Windows2000)
Do you have registered the dll?
Post by Guest »
... registered, unregistered and registered again :-) - still I don't find these functions...
Anonymous wrote:... registered, unregistered and registered again :-) - still I don't find these functions...
Try to reboot. If you have a sub menu option, so you have the old version...
Post by Guest »
... thanks, now it works.
It seems to work alright, but Olympus RAW Files are resized to half resolution. And although I changed language to German, the entry "convert" still appears in English.
Best wishes
Frank
Anonymous wrote:And although I changed language to German, the entry "convert" still appears in English.
The german translation is not finished
LNG !
:arrow: Guest
:) Hello !
• You may complete the German section, since there is a LNG text-file ! :D
- So, something like :
113=Umwandeln…
or so, the German and me… ;) You have also 224=Convertir (in French…)
:mrgreen: VG
Post by Guest »
... thanks, Clo, I'll try that!
Frank
I have no pending request for translation. Did I miss something?
Helmut (German translator)
Incomplete, O yea !
:arrow: helmut
• Hello !
• I checked the sections in the <XnViewShellExt.lng> file, only the English and French ones seem complete currently.
In example :
[en] = 74 entries, [en-str] = 56 entries.
- Same in French (with a bunch of corrections to do…).
- All other sections are pretty incomplete… :|
:mrgreen: G.
Re: Incomplete, O yea !
Clo wrote:... - All other sections are pretty incomplete… :|
Thank you for your explanation. Pierre has never asked me to translate anything, this is why there is no German translation. I guess it's the same with all the other translations. :-|
@Pierre: Could you please clarify? How much time do translators have for translating the XnView Shell Ext 2.0 strings?
helmut wrote: @Pierre: Could you please clarify? How much time do translators have for translating the XnView Shell Ext 2.0 strings?
You have not received it?? A week is enough?
