XnView 1.92 downloads: Different files
Markus
Post by Markus »
Well, this is not actually a bug in XnView, but in different download files:
I just downloaded all possible files and found that there are files with different dates and versions in separate download packages from same file.
Some files are (way) older or newer than in default program downloads.
For example, you can look in for different addons and at least with some translations may be included in one, but missing from another download-file.
Re: XnView 1.92 downloads: Different files
Markus wrote:Well, this is not actually a bug in XnView, but in different download files:
Which package? And which files?
xnview wrote:Which package? And which files?
I guess there's different files on download server 1 & 2. Just a guess...
Markus
Post by Markus »
I didn't make notes from those, so I have to do the verification again. It will take some time, will start immediately. :)
Markus
Post by Markus »
Report complete!
Did not include differences, if only date is different, but the file data is same. But if the file size is same in the following report list, the files ARE different!
Here is report of different files between zip-packages downloaded from server 1:
*archive.zip:
FILE: unrar.dll is newer and different in archive.zip:
Size 164352 bytes in archive.zip, modified 2007-12-20 08:37:04
Size 163840 bytes in XnView-win-full.zip, modified 2007-07-21 09:52:56
*help-en.zip:
FILE: help-en.chm is older and different in :
Size 670393 bytes in help-en.zip, modified 2007-01-30 16:28:46
Size 1249075 bytes in XnView-win-full.zip, modified 2007-12-19 16:38:00
*pngout.zip:
FILE: PNGout.lng is older and different in :
Size 443 bytes in pngout.zip, modified 2007-09-34 09:34:34
Size 1354 bytes in XnView-win-full.zip, modified 2007-12-17 11:38:58
FILE: PNGout.xnp is older and different in :
Size 77824 bytes in pngout.zip, modified 2007-09-24 09:35:48
Size 77824 bytes in XnView-win-full.zip, modified 2007-12-19 16:31:00, scanned as different!
*XnShellEx64.zip:
FILE: XnViewShellExt.dll is older and different in
Size 1462784 bytes in XnShellEx64.zip, modified 2007-12-19 14:22:28
Size 1060864 bytes in XnView-win-full.zip, modified 2007-12-19 15:41:54
NOTE: May be ok because of difference between 32-bit and 64-bit versions. Files modified on same day.
*XnView-win-plugins.zip
FILE: CAD-License.txt is older and different in XnView-win-plugins.zip:
Size 3820 bytes in XnView-win-plugins.zip, modified 2005-04-18 16:57:18
Size 4779 bytes in XnView-win-full.zip, modified 2007-03-14 13:22:06
FILE: CADImage.dll is older and different in XnView-win-plugins.zip:
Size 1153008 bytes in XnView-win-plugins.zip, modified 2006-06-05 15:37:36
Size 1858176 bytes in XnView-win-full.zip, modified 2007-03-09 11:22:08
FILE: mpeg.dll is older and different in XnView-win-plugins.zip:
Size 110592 bytes in XnView-win-plugins.zip, modified 2006-02-01 11:02:28
Size 110592 bytes in XnView-win-full.zip, modified 2007-12-19 16:08:34
FILE: slide.exe is older and different in XnView-win-plugins.zip:
Size 188416 bytes in XnView-win-plugins.zip, modified 2007-05-16 10:28:22
Size 192512 bytes in XnView-win-full.zip, modified 2007-12-19 16:08:52
FILE: Xjp2.dll is older and different in XnView-win-plugins.zip:
Size 225280 bytes in XnView-win-plugins.zip, modified 2006-12-07 19:36:40
Size 225280 bytes in XnView-win-full.zip, modified 2007-12-19 16:09:10
FILE: Xsusie.dll is not included in XnView-win-full.zip
*pocket.zip:
FILE: Pocket.xnp is not included in XnView-win-full.zip
*XnShellEx.zip:
FILE: register.bat is not included in XnView-win-full.zip
FILE: unregister.bat isnot included in XnView-win-full.zip
***These files contains same files than in XnView-win-full.zip:
fi.zip (Did not verify other languages...)
ftp.zip
id3.zip
Nconvert-win.zip
nero.zip
paint.zip
template.zip
webs.zip
zip.zip
