PDF generation from tiff, jpeg...
dominique
Post by dominique »
Hi GFLSDK Team and friends,
I 'm testing translation from Jpeg or Tiff images to PDF format.
My objective is to save PDF with JPEG 80 encapsulated images for example.
If input image format is JPEG or TIFF, SDK saves PDF using TIFF LZW compression with no respect of save options.
If I do the same (with identical save options) from PDF input, SDK works fine respecting save options!
Even if save option structure seems to be ok (I use : FormatIndex, Compression and Quality), I think I miss something in options but don't see witch parameters.
Someone to help?
Rgds
Dom
Re: PDF generation from tiff, jpeg...
dominique wrote:Hi GFLSDK Team and friends,
Someone to help?
Rgds
Do you change the Compression?
dominique
Post by dominique »
Yes I try to Change the Compression method.
With a JPEG or TIFF input :
If I choose No Compression, I have a PDF File which is a little bit bigger than my tiff=> ok that's fine
Same thing with LZW Compression (with a smaller output file).
If I put JPEG Compression with Quality X, the file generated is like a TIFF LZW.
I've compared save options between JPEG source and PDF source with the deboger and every options seems to be the same.
I continue reading Documentation and Forum :)
Thx for your help !
Dom
dominique
Post by dominique »
Here is an exemple of who I do :
GFL_BITMAP              *mBitmap;
GFL_FILE_INFORMATION    mImageInfo;      // Données image
GFL_FORMAT_INFORMATION  mFormatInfo;     // Données sur le format de l'image
GFL_ERROR               mErr;            // Code d'erreur
GFL_LOAD_PARAMS         mLoadOption;     // Options d'ouverture de l'image
GFL_SAVE_PARAMS         mSaveOption;     // Options  d'écriture de l'image
gflLibraryInit();
gflGetDefaultLoadParams( &mLoadOption );
mErr = gflLoadBitmap( "toto.tif", &mBitmap, &mLoadOption, &mImageInfo );
if (!mErr)
                gflGetDefaultSaveParams(&mSaveOption);
                mSaveOption.FormatIndex = 54;
                mSaveOption.Compression = GFL_JPEG;
                mSaveOption.Quality     = 80;
                mErr = gflSaveBitmap( "toto.pdf", mBitmap, &mSaveOption);
                int toto = 13;          // break point
gflLibraryExit();
May it can show you my mistake!
Dom
Ok, right. Please send me your email by PM, i would like to send you a fixed version...
dominique
Post by dominique »
Problem solved with your modifications (library correction sent by e-mail)
Thank you!
PS : Thx to the GFL team for this lib!
Dom
