Folder-Icon in Tree-View changing
Zefiris
Post by Zefiris »
Hi! ...
XnView 1.91.1 an 1.91.2 on Windows Vista Business german:
Every time i click on a folder in the tree-view the folder icon of the previously selected folder changes from the standard yellow folder icon to the standard file icon (the white empty piece of paper).
I hope you know what I mean.
Zefiris
Re: Folder-Icon in Tree-View changing
Zefiris wrote: Every time i click on a folder in the tree-view the folder icon of the previously selected folder changes from the standard yellow folder icon to the standard file icon (the white empty piece of paper).
Could you post a screenshot, please?
bugmenot
Post by bugmenot »
I have Windows Vista Home Premium.
I'm using XnView 1.91.4.
The bug is this: If I'm seeing a folder with pictures inside, the icon shows as a yellow folder (the regular icon).
But when I change to other folder, the previous one icon changes to a "white paper icon".
And stays that way until I click on that folder again to see the content.
Oh, I must add that this icon problem, is on the "folder tree".
Thanks! I hope I was clear enough
pepemosca
Post by pepemosca »
I have the same problem here with the 1.91.5 :(
pepemosca wrote:I have the same problem here with the 1.91.5 :(
On vista too?
pepemosca
Post by pepemosca »
On vista too?
Ups, sorry: Yes, on Windows Vista Home Premium.
I was posting as bugmenot :)
pepemosca
Post by pepemosca »
As you can see here:
The problem is the "red rectangle".
But I must add that the "folder icon", is updated when I'm seeing the folder.
The "yellow rectangle" folder, was a originally a "folder icon", then I click on it to see the contents.
Then I click on a different folder and the "yellow rectangle" folder pass to a "white icon".
Then when I go back to the "yellow rectangle" folder, the icon is correctly a "folder icon".
Was I clear :P
Grzesiek
Post by Grzesiek »
Exactly the same problem here:
- 1.91.5 and lower versions too! (at least from 1.91)
- Vista Bussines PL
"Visited" folder icons turn "sheet of paper" icons.
ADD: But it doesn't affect special folder icons (like marked on yellow on linked picture)
http://kociak.info/TEMP/xn2.JPG
pepemosca
Post by pepemosca »
Grzesiek wrote:Exactly the same problem here:
- Vista Bussines PL
http://wozniak.risp.pl/TEMP/xn2.JPG
Yes, you are right :)
pepemosca
Post by pepemosca »
Sorry to bother, could you find "why is the problem"?
Thanks!
XnView 0.97.1 64bits (Oct 13 2020)
Windows 10 20H2
pepemosca wrote:Sorry to bother, could you find "why is the problem"?
Thanks!
It's fixed in the 1.91.6
pepemosca
Post by pepemosca »
Thanks!
Cool! Thanks!
Windows 10 20H2
pepemosca
Post by pepemosca »
It's fixed! Thanks!
Windows 10 20H2
