Next/Previous image delay compensation
Flake
Post by Flake »
Image changing takes a while to go to next/previous image, but sometimes it goes skipping some images not even displaying them.
Does it need so much CPU to work without glitches? Cache options are enabled, but even then this delays and skipping are annoying.
Look on Google Picasa2 on AcdSee 3.0 (no any cache mention though) performance, they work perfect even with large images. And please don't say "if you like - so use them instead".
I hope it can be improved soon
Thanks
coverback
Post by coverback »
I'm experiencing something similar here, but not just on change, but rather on resize or on change in 'fit to window' mode.
and yes, asdsee 3 was doing the resize faster, but i don't know which algorithm was used there though..
Re: Next/Previous image delay compensation
Flake wrote:Image changing takes a while to go to next/previous image, but sometimes it goes skipping some images not even displaying them.
Do you have tried with 'Read ahead' option?
Flake
Post by Flake »
xnview wrote:Do you have tried with 'Read ahead' option?
Flake wrote:Cache options are enabled, but even then this delays and skipping are annoying.
Yes, I've tried
AlterMann
Post by AlterMann »
If you disable "High quality zoom" options, speed is icreased!
So, i think the problem is relevant to this algorithm.
Also -another suggestion- "read one image ahead" options must be work backward too!... (Even more than "one" image.)
AlterMann wrote:If you disable "High quality zoom" options, speed is icreased!
High zoom is slow and can be slower for big picture!
pepemosca
Post by pepemosca »
AlterMann wrote:Also -another suggestion- "read one image ahead" options must be work backward too!... (Even more than "one" image.)
I vote to that: more than "one" image ahead and back!
I have 2GB of RAM, I should be able to manage more than 1. :)
XnView 0.97.1 64bits (Oct 13 2020)
Windows 10 20H2
