OpenEXR files don't load
wOLVERINe
Post by wOLVERINe »
Hi..
I'm not sure why but for some reason none of the OpenEXR files I generate using the 3d packages Maya and/or XSI can be opened by XnView B5. The files open fine in Photoshop or Digital Fusion.
I keep getting the error,
" Format of the file <Yada> could not be determined. "
1.84 seems to have the same problem.
If you need files to test on.. Lemme know..
Oh.. thanks for the Gamma feature for OpenEXR..
I just wish I can test it soon :)
Cheers,
wOLV.
Re: OpenEXR files don't load
wOLVERINe wrote:Hi..
Cheers,
wOLV.
Could you send me your exr file?
wOLVERINe
The files...
Post by wOLVERINe »
Here are two files..
These come straight out of Maya 7 and 8.. and have different frame depths.
http://www.ginodammers.com/_GETLOST_/te ... x8_bit.exr
http://www.ginodammers.com/_GETLOST_/te ... 32_bit.exr
Cheers
wOLV.
Olivier_G
Re: The files...
Post by Olivier_G »
Both files displayed without problem in Beta 6 -> closed.
Olivier
