RC4: Copy/Move feature
Locked
deus-ex
Post by deus-ex »
2xnview
Will you enhance the copy/move feature like i described here, Filecopy, Suggestion Nr. 9?
This would overcome the neccessity to visualy compare identical files for instance.
Friendly regards, deus-ex.
deus-ex wrote:2xnview
Yes, try it!
deus-ex
Post by deus-ex »
Excuse me, i did try v1.74 RC4 before posting my question. It allways opens the visual compare window when copying same file to same target. Also i can not find any settings in options menu to influence its behaviour?
Regards, deus-ex.
Deus-Ex,
deus-ex wrote:Excuse me, i did try v1.74 RC4 before posting my question. It allways opens the visual compare window when copying same file to same target. Also i can not find any settings in options menu to influence its behaviour?
There is the copy/move dialog, but it does not have all the options that you have described in your proposal, post "Usability suggestions".
Greetings,
Helmut
Locked
