B1: Closing an Hex View -> Crash
Olivier_G
Post by Olivier_G »
When closing an Hex view to revert to another opened Hex view, XnView will crash.
To reproduce: select two files, open them in Hex mode (Menu>Tools>View in Hex mode) and close the current window -> Crash.
(it won't happen if you switch to another normal view in between, as it will revert to that normal view instead of the Hex view)
Olivier
I couldn't reproduce the problem on Windows XP SP2. I've used two JPG files.
OK here
—> Olivier_G
:) Good morning,
• Same than helmut, I can't reproduce this with one JPG and a (big) animated GIF, both displayed in hexa; I can switch from one to the other n… times, all is OK.
• Under XP-Pro SP1 - Fr¦English
:mrgreen: KR
Olivier_G
Re: OK here
Post by Olivier_G »
Good morning everyone,
Clo wrote:I can't reproduce this with one JPG and a (big) animated GIF, both displayed in hexa; I can switch from one to the other n… times, all is OK.
The problem is not when I just switch from one to another: it's when I close an Hex view and XnView should then focus on another Hex view (ie: activate 2 hex views in a row, then close). I get it systematicaly on XP SP2 (tried with several JPEGs and all kind of files).
(do you see what I mean? :| )
Olivier
I did so
:) Hello !
• I did this too : I closed one hexa view, then XnView displayed the remaining one, no problem. Is it the point ?
:mrgreen: KR
Olivier_G
Re: I did so
Post by Olivier_G »
Clo wrote:I did this too : I closed one hexa view, then XnView displayed the remaining one, no problem. Is it the point ?
Yes... :? ...I always get a crash. Strange... :(
Olivier
ouistiti
Post by ouistiti »
No crash here !
Paul
1,77245385090552...
ckit
Post by ckit »
I cannot reproduce this bug.
Re: I did so
I can't reproduce it, do you have a way to reproduce it?
Olivier_G
Re: I did so
Post by Olivier_G »
xnview wrote:I can't reproduce it, do you have a way to reproduce it?
It seems I am the only one able to reproduce it... :?
Pierre: I send you my ini file by email. Maybe it will be easier to reproduce with it.
Olivier
Re: I did so
I guess that you are the only one who can verify whether this has been fixed or not. Could you please check, Olivier?
Olivier_G
Post by Olivier_G »
Yep... No bug in Beta 2! Thanks Pierre.
(-> Closed)
Olivier
