XnView 1.74 Release Candidate 1 (Windows)
Locked
XnView v1.70 RC1 est disponible ici : http://www.xnview.com/beta/XnView-RC1.zip
Si vous trouvez des bugs, merci de me contacter.
WhatsNew:
Added : Gammasat, conbright, autocrop in multi-convert & NConvert
Added : New submenu for MRUF
Added : Use EXIF orientation
Added : EXIF orientation in "JPEG lossless rotation"
Added : HLS & Sepia in multi-convert & NConvert
Added : Use of key "context menu" in browser
Added : Text template (iptc, exif, ...) in multi-convert
Added : $ for source folder in NConvert
Added : Fit option for fullscreen
Added : Scan headers option
Added : Option to have old zoom feature with left button
Added : Custom size/ratio
Added : High quality preview in browser
Added : Loading WMF in full resolution
Added : (Advanced) Operations can be moved
Added : Add/Merge option for batch IPTC
Added : Flat style thumbnail option (windows only)
Added : Horizontal/Vertical windows tiling
Added : FlashCam frame, Cisco IP Phone & JBIG-2 read format
Added : Lossless crop
Added : lossless operations in toolbar
Added : Options for camera RAW format
Added : Describe on folder
Added : Use EXIF DPI informations
Changed : Browser/Show text & Show hexa moved to options
Changed : jbigkit 1.6
Changed : MRW,ORF,NEF
Fixed : Next/Previous
Fixed : <IPTC:Keywords>
Fixed : DDS writed by DirectX9
Fixed : View picture sorted by image property
Fixed : Move lost item focus
Fixed : Associations on Xp (windows only)
Fixed : ESC quit fullscreen view from browser
Fixed : After "Save As", the picture has now the new name
Fixed : XWD
Fixed : When user can write in XnView folder, cache will be created in "Document Settings" (windows only)
Fixed : 16000x16000 limit for gif files
Fixed : Resize selection & Fit image
Fixed : Deselecting item in browser don't update preview (windows only)
Fixed : Some problems with video player (windows only)
Fixed : Describe with search results
Fixed : Multiconvert with CRW/High
Fixed : -ratio with resize & canvasresize problem in NConvert
Fixed : XnView Fit & Fit to image
Fixed : grey scale image resizing
Fixed : Slow scrolling (windows only)
Fixed : Playing movie in fullscreen (windows only)
Fixed : Fit to desktop + fullscreen
Fixed : Iff writing
Fixed : Casio makernotes
Fixed : Problem with old language dll (windows only)
Fixed : With many files, all thumbnails are not created
Fixed : Many other things...
Mar.mack
Post by Mar.mack »
J'ai remplacé l'exe dans mon répertoire de Xnview
J'ai trouvé pleins de bugs :)
Si tu cliques sur un fichier en mode parcourir et que tu choisis (vi un clic droit) 'Générer la liste des fichiers', le volet de visualisation disparait...
'Renommer par lot' ne fonctionne pas non plus.
'Convertir fait disparaitre le volet de l'arborescence des docciers'
Autre bug : je peux pas accéder aux options... Xnview plante.
Pour le reste j'ai pas testé.
Sinon, la fonction de renommage est très bien depuis la version 1.60 (je crois) mais il arrive que des fichiers utilisent des noms comportants des '.'... et Xnview supprime tout ce qui se trouve après ce point.
Pourras-tu ajouter une option permettant non pas de remplacer l'extension du fichier mais de l'ajouter en fin de nom ?
Mon OS : MS Windows 2000 Pro SP4 + correctifs
Mar.mack wrote:J'ai remplacé l'exe dans mon répertoire de Xnview
Surtout ne pas utiliser les langues de la 1.70.4!!!!!!!!!
Euh comment ça?
Mar.mack
Post by Mar.mack »
Forcément... je me fais toujours avoir :)
Euh comment ça?
Eh bien, si j'ai un fichier qui se nom 'R.D.C. appart'.
Qui est en fait une image JPG me venant d'un mac, disons.
Si je la renomme avec Xnview (avec un lot d'autres images)... elle va devenir 'R.D.C.jpg'...
Oui mais voilà, j'ai un fichier 'R.D.C. jardin' aussi, donc message d'erreur m'indiquant que le fichier 'R.D.C.jpg' existe déjà.
Je devrais donc le renommer à la main.
Est-ce plus claire?
Mar.mack wrote:[q] Surtout ne pas utiliser les langues de la 1.70.4!!!!!!!!! [/q]
[q]Euh comment ça?[/q]
Est-ce plus claire?
Ah oui, dans ce cas vire l'utilisation d'une extension.
Mar.mack
Post by Mar.mack »
nomme un fichier quelconque adr.ess.e.txt ...
et regarde ce que donne l'aperçu quand l'extension est cochée ou que la case personnalisé est coché (mais vide...) dans le traitement par lot...
Perso j'ai : .txt dans le second cas...
Mar.mack wrote:nomme un fichier quelconque adr.ess.e.txt ...
Euh comprends pas, .txt est l'extension....
Par exemple, si tu prends le template <Filename>, tu peux ajouter une autre extension.
Mar.mack
Post by Mar.mack »
Je vais faire des captures d'écrans et tu vas comprendre.
Mar.mack wrote:Je vais faire des captures d'écrans et tu vas comprendre.
:D
Locked
