Like the subject, Is there any command line options for Xnview pocket to use for creating a shortcut?
It would be great to take a screen capture or do the specific task with only one tap on a shortcut.
Thank you
Is there command line options for Xnview Pocket?
Moderators: XnTriq, xnview
Re: Is there command line options for Xnview Pocket?
No, you would like that for capture only?zybernav wrote:Like the subject, Is there any command line options for Xnview pocket to use for creating a shortcut?
I think other functions might also be useful, such as, opening pictures in full screen view or open slideshow from a file list. Something for automatic execution.xnview wrote:No, you would like that for capture only?zybernav wrote:Like the subject, Is there any command line options for Xnview pocket to use for creating a shortcut?
Thanks
Let me second that request. I think that launching a slideshow using a command-line option would be great. It would also be nice to have a command-line option to initiate a screen-capture of a window.zybernav wrote:I think other functions might also be useful, such as, opening pictures in full screen view or open slideshow from a file list. Something for automatic execution.xnview wrote:No, you would like that for capture only?zybernav wrote:Like the subject, Is there any command line options for Xnview pocket to use for creating a shortcut?
Thanks for a wonderful tool!
Such a command line option for screen capture would be very great. Please insert it in XnView for Smartphone!zybernav wrote:...take a screen capture or do the specific task with only one tap on a shortcut.
An option to automatically save the pics would be great, too!
Yes indeed, please add my enthusiastic vote too! Definitely for screen capture, but also for other options pleasezybernav wrote: I think other functions might also be useful, such as, opening pictures in full screen view or open slideshow from a file list. Something for automatic execution.
Thanks
