A3: Tree and preview locked…
:arrow: Pierre
:) Hello !
• With Alpha 3, the small buttons in the browser to show¦hide the tree and the preview no longer work !
- I mean : I used them once to hide the items, but then impossible to reopen them !
- The arrow-points are highlighted in red, as usual, but no action when clicking on…:|
• So, now I can't use the browser at all; I didn't find means to reopen the tree and the preview, it's locked.
- None menu-entry works at this, even when ticked…
:mrgreen: Kind regards,
Re: A3: Tree and preview locked…
Clo wrote::arrow: Pierre
:) Hello !
With which layout? I have not the problem...
JohnFredC
Post by JohnFredC »
Layout #7 (from the top) is still missing its little splitter buttons in A3.
John
Solved, but…
—> Pierre
• Solved, was caused by the previous French DLL…
- It works now after I have patched the last version (maybe some command-number changed ?)
• However, like JohnFredC points out above, the buttons are missing still with the Layout # 7, I confirm.
- Aside : Still hard to spot and to catch these buttons… :|
:mrgreen: KR
ouistiti
Post by ouistiti »
Indeed, such misadventures might not occur… This is time wasting while testing.
- Since I had not the issue with the new DLL, it was not too hard to find the snag.
- However, currently I may say that the Clo's corrections are indispensable, because too many items are not translated and some interface items have defects…
Please, could you avoid to change the commands continually ? That binds to remake the corrections n… times :(
- Moreover, this is not the same in other programmes, the command-numbers are kept through the versions…
- This helps when one uses text files for the languages, that I hope to get before my funeral… :P
Regards
Paul
1,77245385090552...
ouistiti wrote:Indeed, such misadventures might not occur… This is time wasting while testing.
I'll try, but in alpha/beta stage, i'll change again some id...
ckit
Post by ckit »
JohnFredC wrote:Layout #7 (from the top) is still missing its little splitter buttons in A3.
Fixed in Beta 1.
