Xnview Shell Error
KajE
Xnview Shell Error
Post by KajE »
Hi Xnview-Support, there's an error with the ShellExtensions, best described by a picture you can find at the following URL:
(Size: 85,59 Kb)
Shell Extensions Version: 1.4.0.0 (Filesize: 942.080 Bytes)
OS: Windows XP SvP2, German
Some assumtions and additional infos in this context:
(1) Seems that this bug occurs (first) after installation of Macromedia Studio 8.
(2) regsvr32 -u and vice versa (including a 'logout/login' or a reboot) doesn't solve this problem
Best regards,
Kaj E. Ozolins
Re: Xnview Shell Error
KajE wrote:Hi Xnview-Support, there's an error with the ShellExtensions, best described by a picture you can find at the following URL:
(Size: 85,59 Kb)
Best regards,
Kaj E. Ozolins
If you remove XnViewShell, you have no more this problem?
KajE
RE: Shell Extension Error
Post by KajE »
Pierre wrote:If you remove XnViewShell, you have no more this problem?
No, Pierre, after doing an unreg (regsvr32) the context-menue displays absolutely correct.
If you'd like me to test something else -- dont't hesitate to ask.
Kaj
Re: RE: Shell Extension Error
Kaj
Someone has the same problem??
