Problem with save in TIFF format
Post by Guest »
I would like to get an image from a window and convert it into TIF black&white format.
import HWND and change color depth are done (no message error)
but i don't manage to save bitmap into TIF file (error=GFL_ERROR_BAD_FORMAT_INDEX).
I tried other formats to test => same error.
what's wrong with my code ?
                GFL_ERROR err;
                GFL_BITMAP *bitmap;
                GFL_RECT rct;
                rct.x=rectSel.left; // WINAPI RECT rectSel : global var
                rct.y=rectSel.top;
                rct.w=rectSel.right-rectSel.left;
                rct.h=rectSel.bottom-rectSel.top;
                err = gflImportFromHWND (hwnd, &rct, &bitmap);
                if (err) goto errato;
               GFL_BITMAP *bitmapOut;
               err = gflChangeColorDepth (bitmap, &bitmap,GFL_MODE_TO_BINARY, GFL_MODE_HALTONE90_DITHER);
                GFL_SAVE_PARAMS sp;
                gflGetDefaultSaveParams(&sp);
                sp.Flags = GFL_SAVE_REPLACE_EXTENSION;
                sp.FormatIndex = gflGetFormatIndexByName("tiff");
                err = gflSaveBitmap("sortie.tif", bitmap, &sp);
                return TRUE;
                errato:;
                 if (err) exit(err) ;
Re: Problem with save in TIFF format
Anonymous wrote:I would like to get an image from a window and convert it into TIF black&white format.
Strange, all seems to be good.
Try to replace by:
err = gflChangeColorDepth (bitmap, NULL,GFL_MODE_TO_BINARY, GFL_MODE_HALTONE90_DITHER);
