A: Problem with opening file
DOS386
Post by DOS386 »
<Moderator's note: This topic has been split from another topic>
Pierre / XNview wrote:
File/Open in which mode??
And what do you means by 'illegal activity'???
Open:
- ordinar "open" or "hex" fails
- Via "browser" or "Recent files" works
"illegal activity"
This is a "windows" internal error message (you will have it en Francais
probablement :wink: )
XN 1.82.4 never (almost ?) generates this, think you get this problem in
1.90 fixed during alpha or beta developement :)
Re: Bugs
Open:
"illegal activity"
Could you explain me more, i can't reproduce it??? You means File/Open menu??
DOS386
File open bug
Post by DOS386 »
Yes, I mean "File" -> "Open", "File" -> "Open in Hex mode", CTL-O, CTL-H,
and the direct "Open" (having many possible symbols available) button
(supposed to display the directory) do not work.
Images are accessible only via "browser" or "recent files" (bypassing
the directory).
Re: File open bug
the directory).
Strange, for me File/Open works. Someone with the same problem???
parsec
Post by parsec »
I have the same problem. Ctl-O doesn't work. I am using Win98SE (which I don't think is relevant).
parsec wrote:I have the same problem. Ctl-O doesn't work. I am using Win98SE (which I don't think is relevant).
Really, someone with the same problem on 2K or Xp??
Olivier_G
Post by Olivier_G »
It works here on XP... :?
Olivier
Np pb.
:) Hi !
• No problem here under XP-Pro SP1, it works fine…
:mrgreen: KR
DOS386
BUG (open)
Post by DOS386 »
CTL-O does not work only or all other methods I mentioned also ?
It probably IS relevant ... since I have same bug on same :bug:
I updated to the new Alpha ... bug persists :bug:
parsec
Post by parsec »
Neither Ctrl-O nor File/Open works. If I double click on a graphics file it works fine. I have tried removing all extraneous programs with no effect. No problems with 1.82.4.
DOS386
Bug fixed ?
Post by DOS386 »
Bug no longer occurs. 8) Did you fix it in the Alpha 2 or 3 version ?
But I am on a different PC now.
According to NTOSKRNL_VXE this is fixed. -> Closed
@NTOSKRNL_VXE: If needed you can download 1.90 alpha 1 and try to reproduce this.
DOS386
Fixed !!!
Post by DOS386 »
It is fixed. :)
