I can not get XnView to display the correct colors on Intel Mac Mini's. The same setup on PowerPC Mac Mini's works fine.
A screenshot of the problem can be found here:
http://dasbox.net/temp/xnviewcolorscreen.jpg
The original image can be found here:
http://www.userfriendly.org/cartoons/ar ... 001546.gif
I get the same problem with jpeg png and tiff files as well. I have not tested outside of these four formats (gif, jpeg, png, and tiff) but I assume the result would be the same with any image regardless of format.
Some good news however is that XnView does save images correctly and when those images are opened in other programs the images display without color problems. The screen shot you see was convered from tiff to jpeg using XnView on the same machine the screenshot was taken from.
XnView on Intel Macs Display Strange Colors
Re: XnView on Intel Macs Display Strange Colors
I think that you have a Mac Intel?? So it's normal, i must build an intel port...jonathanw wrote:I can not get XnView to display the correct colors on Intel Mac Mini's. The same setup on PowerPC Mac Mini's works fine.
When might we see an OS X Intel binary avaiable?xnview wrote:I think that you have a Mac Intel?? So it's normal, i must build an intel port...
I'll try to build it before 2 weeks, i must check that i have all dev kit for inteljonathanw wrote:When might we see an OS X Intel binary avaiable?xnview wrote:I think that you have a Mac Intel?? So it's normal, i must build an intel port...
Thanks that would be great! If you could please let me know when you have it ready.xnview wrote:I'll try to build it before 2 weeks, i must check that i have all dev kit for intel
Still no universal binat of XNview?
Hi, this prgrams is awesome, i appreciate it a lot!
any chance of mac intel compatible version?
Re: Still no universal binat of XNview?
Yes, when i'll have an intel macAberracus wrote:Hi, this prgrams is awesome, i appreciate it a lot!
