Can the SDK be used if your language d/n support callbacks?
bob_chauvin
Post by bob_chauvin »
PowerBuilder d/n support callbacks.
Can the SDK be used for some simple functions like copying from the clipboard, saving as jpg.
Re: Can the SDK be used if your language d/n support callbac
bob_chauvin wrote:PowerBuilder d/n support callbacks.
Yes
