Resizing images
Resizing images
Great tool!!! But. I'm trying to resize pictures. I can't get it to work.
The image description:
test.jpg; 695kb; 3504*2336 pixels Colors:16M
I tried it on two pocket pc's. One with free memory of 42Mb the other with 60Mb ree memory.
I want to resize to 200*150 pixels for web use, while i'm on-the-road.
When i presse resize it doesn't do antyhing.
Does anyone have a solution for this
Tenks
TonSe
Tenks
TonSe
Re: Resizing images
Strange, with 60Mb there is enough space... I'll checkTonSe wrote:Hello,
The same problem
I faced the same problem.
I tried image of 4Mpx - it works OK.
I tried image of 6Mpx and 8Mpx - it does not work.
problem to resize
Nothing happens when I tryed resizing a jpeg 5.67 image from a Canon PowerShot A650 tranfered to Ipaq 214.
But with a smaller size from the same image (obtained without problem using trial version of a Resco software) I can resize it with XnView poket.
How to resolve this problem?
Re: Resizing images
I found a strange bug in the resize-option:
when I resize a JPG file the image looks rather smooth,
however when I try to resize the same file (but in this case converted into PNG format with the same pixel-dimensions using XNVIEW for windows)
the image looks very "quantisized" with a large amount of staircasing.
The PNG image looks fine under XNVIEW for windows,
so it has something to do with the image-resizer in the pocket-version .
I have version 1.51 on a PDA with WM6.1 .
René
René
Re: Resizing images
I tried to use the programm on a HTC Touch HD with WM 6.1. All the tools (resizing, turning, cutting, ...) do not do anything. And it is imposible to view the pictures in landscape mode (at least I didn't find an option to do so). Am I doing something wrong or is the programm simply not working?
Re: Resizing images
No answer at all?
A programm that works fine is Spb Imageer.
Re: Resizing images
Which picture size do you try?sssnej wrote:I tried to use the programm on a HTC Touch HD with WM 6.1. All the tools (resizing, turning, cutting, ...) do not do anything. And it is imposible to view the pictures in landscape mode (at least I didn't find an option to do so). Am I doing something wrong or is the programm simply not working?
Re: Resizing images
It does work perfectly. What got me in the beginning though is that you have to push the "resize"/"adjust"/etc.. button, not the "ok" button in the task bar, that just closes the dialog.sssnej wrote:I tried to use the programm on a HTC Touch HD with WM 6.1. All the tools (resizing, turning, cutting, ...) do not do anything. And it is imposible to view the pictures in landscape mode (at least I didn't find an option to do so). Am I doing something wrong or is the programm simply not working?
