Batch Convert: Cannot add DNG files using Add Folder dialog
absolution
Post by absolution »
It's not possible to add DNG files (and probably also other Camera Raw files) to batch queue using Add Folder dialog. XnView ignores DNG files in the folder and subfolders and adds only TIF, JPG etc.
XnView 1.82.4, Windows XP
Re: Batch Convert: Cannot add DNG files using Add Folder dia
absolution wrote:It's not possible to add DNG files (and probably also other Camera Raw files) to batch queue using Add Folder dialog. XnView ignores DNG files in the folder and subfolders and adds only TIF, JPG etc.
Right, i'll fix it
