How to set PNG transparency color?
Re: How to set PNG transparency color?
is there a "set transparency color" in the batch converter?
You have an option in option/Write/PNGCoDEmanX wrote:is there a "set transparency color" in the batch converter?
Hi, I am trying to convert from EPS to PNG with transparent background. The transparent color should be white 255. In Options > Write > PNG I set 255 and in Read I check the Compose image with transparency. Unfortunately I still cant receive the PNGs with transparent background. Any ideas? Thank you
- Moderator & Librarian
Welcome to the forum, Gitchev (-:
Did you reduce the color depth of the converted file prior to saving it?
PS: Recommended settings
