= does not work for zoom in [browser fullscreen mode]...
= does not work for zoom in [browser fullscreen mode]. Please fix this. Thanks.
OK here
- It works here under XP-Pro and a French AZERTY keyboard.
- Also “–” as lowercase on the «6» alpha key works for Zoom out…
- I guess this has been already discussed here, maybe a Search ? …
Keyboards…
—> TsunamiZ
Hello !
• If you want to avoid these issues, use the Numpad keys…
—> Pierre
Hi !
• Here, I get Zoom+ if I use the "=" key as well !
- This is abnormal, since with my French keyboard, I would ought press Shift+= (to get the alpha "+"), which works too for Zoom+ !
- I guess that a keyboard info is missing to state in the programme…
KR
—> Pierre
A note
Re: Keyboards…
Strange, i can't only zoom in by shift+=, and i have checked, it's '+' that is used for zoom in....Clo wrote: • Here, I get Zoom+ if I use the "=" key as well !
I can confirm !
• I can confirm ! Here, I get ZOOM + with only the "=" key with a quite normal AZERTY Logitech French keyboard !
- Did you test under XP ?
