add a hot key to call system context menu display?
Post by Guest »
in Acdsee you can hold Ctrl and Click files to call system display... and compress or send it in brower mode without open Explorer.
Re: add a hot key to call system context menu display?
Anonymous wrote:in Acdsee you can hold Ctrl and Click files to call system display... and compress or send it in brower mode without open Explorer.
ok, i'll try to add it
