button in print-setup is named "print" - that's c
Andreas M.
Post by Andreas M. »
Using xnview 1.82.2 on Windows XP
Go to file -> print-setup
the button to close that window is named "print" (in german "Drucken").
That's confusing... it should better be named "Okay", because if you click on that button it only closes that window and doesn't print anything.
User expects that it prints something out if you click on "print"!
Re: button in print-setup is named "print" - that
Andreas M. wrote:Using xnview 1.82.2 on Windows XP
Yes, but this dialog is the standard not mine...
andreasm82
Post by andreasm82 »
I know that it is standard, but I've got a lot of other programs which use this print-dialog and there's an "ok"button.
I think there must be a trick to change the labels of the button...
If I had more experience in programming I would help you
andreasm82 wrote:I know that it is standard, but I've got a lot of other programs which use this print-dialog and there's an "ok"button.
Ok, i'll search
Mike2005
Post by Mike2005 »
xnview wrote:Ok, i'll search
Maybe you'd better use the print setup dialog box than the print property sheet.
