Sequence convert is placing the file chosen in the "End" input box, instead of the "Start" input box. It is backwards.
Files in folder: S4020087.JPG through S4020159.JPG
A. File chosen to begin with: S4020101.JPG
--Actual result:
Start: 4020087 End: 4020101
--Desired result:
Start: 4020101 End: 4020159
--Actual result:
Start: 4020087 End: 4020087
Fixed. v.1.82
[Fixed]Sequence convert start/end boxes mixed up.
Re: Sequence convert has start/end boxes mixed up.
Right i'll fix itmarsh wrote:Sequence convert is placing the file chosen in the "End" input box, instead of the "Start" input box. It is backwards.
--Actual result:
--Desired result:
--Actual result:
