Bugs in gflC C++ Wrapper (gflCBitmap.cpp)
MaierMan
Post by MaierMan »
Code looks like this:
GFL_ERROR	GFLC_BITMAP::create(const GFLC_BITMAP & bitmap)
	return create(bitmap.getType(), bitmap.getBitsPerComponent(), bitmap.getWidth(), bitmap.getHeight());
While it must be:
	return create(bitmap.getType(), bitmap.getWidth(), bitmap.getHeight(), bitmap.getBitsPerComponent());
as of:
GFL_ERROR					create(GFL_BITMAP_TYPE type, GFL_INT32 width, GFL_INT32 height, GFL_UINT16 bits_per_component=8, GFL_INT32 padding=1, const GFL_COLOR *color=NULL);
Because of this bug neither the copy c'tor, operator= nor create(bmp) works correctly ;)
Furthermore there are several instances of GetGFLColor (which must be getGFLColor).
Re: Bugs in gflC C++ Wrapper (gflCBitmap.cpp)
MaierMan wrote:Code looks like this:
While it must be:
as of:
Ok, thanks...
