Problem with grid display at V1.82.1
I'm using V1.82.1 (06/FEB/2006) on WinXP-Pro (SP2) and Win2000 (SP4).
I see no difference in the grid, if I change the value at the key "GridType" in the ini-file. Regardless which value I use (0,1 or 2), I always get the same strangely grid display after restarting XnView. The first column is not numbered, the second column starts with "1", the third with "2" and so on.
Also the rows are not numbered at lower zoom levels. If I increase the zoom, at some level I get the letters "A", "B" and so on. If I increase the zoom level more, the letters will change "A"-->"AA"-->"AAA" and "B"-->"AB"-->"AAB" and so on.
Grig---grid---
—> Maiger
Hello, welcome aboard !
¤ I had opened an old thread about the grid-improvement, maybe did you read it THERE ?
¤ It seems that only the square shape maintenance has been fixed up…
- However, you are right somewhere, since while «zooming in» progressively (5% step is set), I noticed "A" again after "Z", that is abnormal IMHO…
VG
This looks normal… I guess it's a general Win "numbering" mode as alpha, similar to the HD one (IIRC, after “Z” we might have “AA”, after “ZZ” —> “AAA” …).…If I increase the zoom, at some level I get the letters "A", "B" and so on. …If I increase the zoom level more, the letters will change
Re: Problem with grid display at V1.82.1 (V1.82.2)
Thanks for the welcome !Clo wrote:Hello, welcome aboard !
I've read your old thread about the grid-improvement, but the reason for a new thread was the following:
I refer to the change log of V1.82 ....
Added : Add GridSpacing & GridType & KeepGridForNextPrevious as hidden ini
0 > No labels
1 > Displays digits and letters for the X and Y coordinates (like actually)
2 > Displays only digits for X, and letters for Y
GridSpacing & KeepGridForNextPrevious works OK.
GridType doesn't work!
In the current Version 1.82.2, GridType will be set to '1' and should display digits and letters for the X and Y coordinates.
I only get digits for the X coordinates and the strange thing is, the will start with '1' in the second field.
The letters for the Y coordinates appears only at a higher zoom level.
e.g. zoom below 150% will show no letters for Y coordinates, the fields are empty!
IMHO is this a bug in the current version, because the new feature GridType is added and is not working !
Kind Regards
Gerhard
Funny…
- Indeed, a new thread is possible, just see that the Mods could decide, I'm not a Mod here …;)
- The strange thing is that I didn't see the changelog ...
• Well, I will test that is working, and which minimum step can be set for the grid; but certainly the marking off is buggy currently, you are right !
Re: Funny…
File WhatsNew.txt at line 68 in the current V1.82.2 installation ...Clo wrote: - The strange thing is that I didn't see the changelog ...![]()
Regards, Gerhard
Guilty : Search
- You could see some results of the tests I made in the old thread
Buggy for now
• I think we may say that…
- The other entries work though GridSpacing=… could be improved (to get a rectangular mesh), and obviously two supplemental ones are requested and still missing (blurred text)…
- So, Pierre has to fix up and complete this in the next 1.80.3. Some other functions have problems, hence I don't guess that we'll have this version tomorrow…
Re: Buggy for now
Ok, i'll fix itClo wrote:Hello Gerhard!
- So, Pierre has to fix up and complete this in the next 1.80.3. Some other functions have problems, hence I don't guess that we'll have this version tomorrow…![]()
Wha !
- Thanks to fix¦complete this, I guess that then, we'll have the nicest grid-thingy of all viewers !
