Problem with v1.82 Create>Web Page
222fbj
Post by 222fbj »
I installed v1.82. When I use the Create Web Page, the Thumbnail page has no images (thumbnails). It does shown the IPTC Caption as I have specified in the Create Web panel.
Is this a bug? Could I be doing something wrong? I have been using the Create Web (in previous versions) without a problem.
thanks
Re: Problem with v1.82 Create>Web Page
222fbj wrote:I installed v1.82. When I use the Create Web Page, the Thumbnail page has no images (thumbnails). It does shown the IPTC Caption as I have specified in the Create Web panel.
Strange i have no problem. Which template do you use? Which parameter?
222fbj
Post by 222fbj »
I put screen captures of the Create Web panel, and the output, at http://www.pbase.com/enterprise/inbox
Any suggestions?
222fbj wrote:I put screen captures of the Create Web panel, and the output, at http://www.pbase.com/enterprise/inbox
Any suggestions?
The problem is that you have enter 0 for height!!!
222fbj
Post by 222fbj »
You are correct...this fixed the problem. But this is a change in 1.82. In the previous version the 0 height would create images 800px wide and the height as needed...and the thumbnails would appear.
With 1.82....If I want to set a max width of 800px, and have no limit on the height...I guess I will put in a very large number for height.
Thanks
Barrett
