Bug: Find -> Move -> Overwriting Files without asking!
Hi
Test This:
-Create
-Search in C:\_ -> Browse
-Drag&Drop the Files to C:\_
-> You will have only C:\_\1.jpg
The other one is lost.
-Used for: I have 1000 Subfolders with around 2000 Pictures and want to but some/all of them to 1 Folder
-Workaround: Change duplicated Filename: Mark all found items (in Browse) -> Rename -> Dublicate " #" only if needed
Greetings
Bruno
Test This:
-Create
Greetings
Bruno
Sorry i can't reproduce it, you have not the replace dialog when you drag a file in folder tree??Dreamer wrote:Confirmed, quite danger bug IMO - when I use "Copy to/Move to", Alt+C/M and drag and drop to folder tree.
When I use shortcuts (Ctrl+X/C/V), 'Confirm file replace' dialog is shown - no bug, but rename button or auto-rename option would be better, af course not in this version.
Right, when I use "Copy to/Move to" or Alt+C/M or drag and drop into folder tree - there is no dialog and file is replaced automatically!xnview wrote:Sorry i can't reproduce it, you have not the replace dialog when you drag a file in folder tree??Dreamer wrote:Confirmed, quite danger bug IMO - when I use "Copy to/Move to", Alt+C/M and drag and drop to folder tree.
Edit - Confirmed also with default settings, any images with the same filename are replaced when you try to move them from search results to other folder.
I can't reproduce it after a search, when i drag a file into folder tree, i have the 'replace dialog'...Dreamer wrote:Right, when I use "Copy to/Move to" or Alt+C/M or drag and drop into folder tree - there is no dialog and file is replaced automatically!xnview wrote:Sorry i can't reproduce it, you have not the replace dialog when you drag a file in folder tree??Dreamer wrote:Confirmed, quite danger bug IMO - when I use "Copy to/Move to", Alt+C/M and drag and drop to folder tree.
With any location?Dreamer wrote:Really strange, since I can always reproduce it with default settings.xnview wrote:I can't reproduce it after a search, when i drag a file into folder tree, i have the 'replace dialog'...
I'll move it to Bugs forum, maybe other users could try to reproduce it...
Yes, any filename, any location.xnview wrote:With any location?Dreamer wrote:Really strange, since I can always reproduce it with default settings.xnview wrote:I can't reproduce it after a search, when i drag a file into folder tree, i have the 'replace dialog'...
Just select and move (read above how) two files with the same filename from search results to other folder, one file is lost.
