RC3: [GPF] Renaming with very long filename crashes
When renaming a file in view mode, a dialog appears for entering the new filename.
In 1.82 RC3 one can enter 256 characters for filename plus extension. This is actually too much and will make XnView GPF. There must be a check that length of filename (name + "." + extension) does not exceed 216 characters. (MS Explorer allows a maximum of 216 characters in total, I guess there's some reason for this).
XnView 1.82 <x>
Re: RC3: [GPF] Renaming with very long filename crashes
helmut wrote:When renaming a file in view mode, a dialog appears for entering the new filename.
Yes, right
ckit
Post by ckit »
Move to -> Will be fixed in Final Release
ckit wrote:Move to -> Will be fixed in Final Release
Yes, this one should be fixed in the final release.
But first this topic will go to group "Confirmed", and then Pierre will fix it and move to group "Will be fixed in Final Release."
Dreamer
Post by Dreamer »
ckit have test version maybe...
