- select any image
- press Ctrl+I (in any mode)
- press Escape
= it doesn't work, minor but quite annoying if you want just check IPTC
Also it looks that there is a focus on 'Write' button, but Space/Enter keys don't work.
I think, focus should be on tabs and bottom buttons.
RC3: Minor: Edit IPTC data dialog
Re: RC3: Minor: Edit IPTC data dialog
Yes, because focus is on caption...Dreamer wrote:- select any image
- press Escape
