Batch Rename > Reset counter each new day; Sorting option
Berti
Post by Berti »
Hello!
Current problem:
I have to rename several hundreds of photos from "IMG_####.jpg" to "YYYY-MM-DD_##.jpg" ( {EXIF:Date Taken [Y-m-d]}_## ).
The photo numbering shall start with 01 again every new day:
With the Batch Rename Tool in its current version I have to select all photos from one single day manually. That is slow and prone to failure.
Suggestion:
I'd like to suggest another option for the Counter (##) you can set in the Batch Rename Tool.
Something like...
Reset counter (#) after variable changes: {EXIF:Date Taken [Y-m-d]}
When the variable string {EXIF:Date Taken [Y-m-d]} (or any other string) changes from one file to another, the counter should reset to its starting value.
The only problem I can think of:
When the files are not in chronological order it could happen that the counter gets resetted and we get duplicate names:
Sorted by file size (and not by name or date)
Therefore a sorting option (e.g. "Sort by Date") would be helpful in the Batch Rename Tool.
This option was present in XnView - but disappeared in XnView MP. I don't know why...
I'd be sooo happy if you could implement such a feature. Thank you!
