View as RAW keyboard shortcut for RAW files when display as embedded
golemus
Post by golemus »
If you want to browse through RAW files (DNG, CR2, RW2, etc...) fast in general it makes sense to have "Embedded preview" under Settings - Formats - Read - Camera RAW enabled.
But once in a while comes a situation that you would want to take a peek of the actual RAW data without modifying this setting.
In FastStone this is possible with "A" keyboard shortcut, if you have embedded previews enabled and press A it switches to viewing actual RAW data.
It would be nice to have this same feature also in XNView MP.
- when pressing A pic would be rendered again from RAW data with same zoom and position.
- it does not have to be "A" it could be anything but preferrable user could replace it in Settings - Interface - Shortcuts or even add it to Settings - Interface - Context Menu.
Re: View as RAW keyboard shortcut for RAW files when display as embedded
